5 members (GrandpasJimmy, Bill Hanlon, UtahYork, fonz8261, Hotrod Lincoln), 125 guests, and 3 robots.
Topics128,193
Posts1,057,246
Members48,466
Apprentice
Apprentice
I have a factory rear end out of my 1958 chevy truck. I'm wondering if it will (line up) fit and work in a 1950 chevy truck.
Get your tape measure out and check, but a buddy of mine changed the rearend in his 51 to a later rearend several years ago and didn't have a problem..the truck is still his daily driver...
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Apprentice
Apprentice
Thanks Stick for the info. I have the rear end and am selling it to someone who has a 1950, so I can't measure to compare, that's why I was wondering.
The width of the '58 will be right for the '50.
It will most likely will need the spring pads relocated.
If it lines up or not is up to the guy doing the work.
Steve
'49 3800
'52 3600
'57 3100
Both are the same width.
The center section from the 58 will bolt right in the 50 housing, if you want to keep the houk brakes. Ether way you will need spring pad work
My Blog
