| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I want to install washers on a '62 c-10. It has single speed wipers and did not come with washers. I don't want to use an original NOS set up. I want to have a newer washer pump under the washer bottle and simply push a button to engage the washers. I'll probably get a set up from some modern vehicle at the junk yard. I don't want to have a seperate button for the washers. Is there a wiper switch similar to the one on the truck now that would also have a push button on it for washers ? I would like to hear from someone who has done this and what they have used. Thanks in advance. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I can't think of any late models that have a switch like that. the washer is usually tied into the signal lever. You might have to go with a vintage switch. you can use almost any washer bottle that has the built in motor though. | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | You replace the existing wiper switch with one for a 66 that has the washer button in it..this is what I did on my 59 Apache that my daughter now has...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
