Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (Otto Skorzeny, IHPWR, GMCJammer51, Hotrod Lincoln, 1 invisible), 560 guests, and 1 robot.
Topics126,780
Posts1,039,296
Members48,100
Most Online2,175
Jul 21st, 2025
#556977 07/19/2009 9:43 PM
i am starting a build in a month or so that will entail a 6.6L duramamx motor onto a 1965 K20. i recently researched my tranny and motor more in depth and found that a ZF S6-650 cannot handle the amount of torque the duramax can put out. i would love to stick with a six speed manual. if anyone knows of any trannsmissions that will work please let me know. if not i was wondering if i can floor mount the shifting controls for an allison tranny?
thanks
Jonathan
Jonathan
_____________
1965 K20 project truck
duramax swap
6speed tranny swap
axle swap
1966 C20 camper special
family heirloom
restoration project
the ZF should be fine, if not pull a trans from a Dodge with the Cummins. it will depend solely on how you drive and how much weight you are pulling.
I know that you can floor mount an eaton.
ok well i am looking to find a six speed and the ZF would work for now but not if i ever want to mod this motor i am getting with a chip or better injectors or anything that would increase the torque. than the zf would be outmatched. i dont have much knowledge of the trannies that will fit to diesels. i honestly didnt know the eaton made transmissions. i will look into it. thank you very much
Jonathan
Jonathan
_____________
duramax swap
6speed tranny swap
axle swap
family heirloom
restoration project
Eaton makes transmissions for the larger straight trucks. Do your research on transmissions. Even the mighty Allison will have issues with enough torque. However if you cant hook up the rear wheels, you cant transfer the torque. That simply equates to wheels spin. do a search for transmission specialist that deal with hopped up diesels. In fact, give the folks at Gale Banks a call. They play with duramax's all the time and get up to 750 hp. they can point you toward a transmission that will live.
Here's one of Banks' DuraMax trucks in action.
Bill Burmeister
Alright well i have been on some diesel forums as well and the only person i have found that has broken a ZF S6-650 was a man who was pulling a sled in high range with a truck that is in the 1500 ft lbs range so i dont think i need to worry about the ZF. i have multiple persons who have the tranny in their trucks with 1000ft lbs+ but i will still research all the info yu have given me. thanks!!!
jonathan
P.S. is there a way to delete threads that you dont use anymore or do they just stay in the archive for someone else to look up?
Jonathan
_____________
duramax swap
6speed tranny swap
axle swap
family heirloom
restoration project
you could pm the moderator to delete threads and posts. They will be glad to do it.
actually they won't be glad to do it, unless there's some fightin goin on, individual threads aren't just for the immediate help of a single poster, the reason there is an archive is so all the wisdom spouted herein is preserved for posterity wink
might be someone next month or next year searching 'ZF S6-650' who could learn something from this thread without having to ask
"MONGO"
"MONGO"
Tis' true, I'd be happy to clean up any non-knowledge sharing posts or make any edits to clean up any spelling/grammar but if it's good stuff then no.
Steve
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
i worded that a little wrong i think. the only thing i really wanted to do was remove them from "my posts" list cause it is getting really long LOL. but it is no big deal. thanks alot guys.
Jonathan
Jonathan
_____________
duramax swap
6speed tranny swap
axle swap
family heirloom
restoration project
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.214s Queries: 14 (0.028s) Memory: 0.6341 MB (Peak: 0.7191 MB) Data Comp: Zlib Server Time: 2025-09-22 20:55:17 UTC
Valid HTML 5 and Valid CSS
