BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
11 members (TUTS 59, niobrarafun, JW51, Gib70, TooMany2count, RBs36, 2-Ton, Charles in CA, Wally / Montana, Shaffer's1950, 46 Texaco),
545
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,277 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Mar 2009 Posts: 57 Wrench Fetcher | Wrench Fetcher Joined: Mar 2009 Posts: 57 | i am starting a build in a month or so that will entail a 6.6L duramamx motor onto a 1965 K20. i recently researched my tranny and motor more in depth and found that a ZF S6-650 cannot handle the amount of torque the duramax can put out. i would love to stick with a six speed manual. if anyone knows of any trannsmissions that will work please let me know. if not i was wondering if i can floor mount the shifting controls for an allison tranny? thanks Jonathan
Jonathan _____________ 1965 K20 project truck duramax swap 6speed tranny swap axle swap
1966 C20 camper special family heirloom restoration project
| | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | the ZF should be fine, if not pull a trans from a Dodge with the Cummins. it will depend solely on how you drive and how much weight you are pulling.
I know that you can floor mount an eaton.
| | | | Joined: Mar 2009 Posts: 57 Wrench Fetcher | Wrench Fetcher Joined: Mar 2009 Posts: 57 | ok well i am looking to find a six speed and the ZF would work for now but not if i ever want to mod this motor i am getting with a chip or better injectors or anything that would increase the torque. than the zf would be outmatched. i dont have much knowledge of the trannies that will fit to diesels. i honestly didnt know the eaton made transmissions. i will look into it. thank you very much Jonathan
| | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Eaton makes transmissions for the larger straight trucks. Do your research on transmissions. Even the mighty Allison will have issues with enough torque. However if you cant hook up the rear wheels, you cant transfer the torque. That simply equates to wheels spin. do a search for transmission specialist that deal with hopped up diesels. In fact, give the folks at Gale Banks a call. They play with duramax's all the time and get up to 750 hp. they can point you toward a transmission that will live.
| | | | Joined: May 2006 Posts: 8,351 'Bolter | 'Bolter Joined: May 2006 Posts: 8,351 | Here's one of Banks' DuraMax trucks in action.
Bill Burmeister | | | | Joined: Mar 2009 Posts: 57 Wrench Fetcher | Wrench Fetcher Joined: Mar 2009 Posts: 57 | Alright well i have been on some diesel forums as well and the only person i have found that has broken a ZF S6-650 was a man who was pulling a sled in high range with a truck that is in the 1500 ft lbs range so i dont think i need to worry about the ZF. i have multiple persons who have the tranny in their trucks with 1000ft lbs+ but i will still research all the info yu have given me. thanks!!! jonathan
P.S. is there a way to delete threads that you dont use anymore or do they just stay in the archive for someone else to look up?
| | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | you could pm the moderator to delete threads and posts. They will be glad to do it.
| | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually they won't be glad to do it, unless there's some fightin goin on, individual threads aren't just for the immediate help of a single poster, the reason there is an archive is so all the wisdom spouted herein is preserved for posterity  might be someone next month or next year searching 'ZF S6-650' who could learn something from this thread without having to ask Bill | | | | Joined: Jul 2000 Posts: 615 "MONGO" | "MONGO" Joined: Jul 2000 Posts: 615 | Tis' true, I'd be happy to clean up any non-knowledge sharing posts or make any edits to clean up any spelling/grammar but if it's good stuff then no. Steve | | | | Joined: Mar 2009 Posts: 57 Wrench Fetcher | Wrench Fetcher Joined: Mar 2009 Posts: 57 | i worded that a little wrong i think. the only thing i really wanted to do was remove them from "my posts" list cause it is getting really long LOL. but it is no big deal. thanks alot guys. Jonathan
