2 members (UtahYork, 1 invisible),
74
Mod | | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | Will the wheels off a 1976-1981 chevrolet truck 3/4 ton truck. Fit on my 1946 chevrolet 3/4 ton truck or is the back spaceing wrong? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | For my 51 I looked for similar rims. What I found was that rims that were 6" in width usually had a backset of 4" or less and that was the critical measurement for me. The main problem was finding rims that wouldn't hit the tie rod ends. Also I had to make sure that the rims would clear the 14" drums in the rear. | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I'm not sure what the '76-'81 wheels were, but if they were 16.5" I'd not use them. Hard to find tires for.
I used the rims from the mid 80's K2500's. They are an 8-lug 16" and don't rub the tie rod ends. They work great on my '46 3/4ton. | | |
