0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55669 01/28/2006 3:06 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | I just picked my springs up at the spring shop. In the "bag-o-parts" to bring home and install on the truck were the spring bolts. The shop said the 11/16ths bolts are "easy" to get, but the nuts that hold em on are very hard to find.
Since the guy doing the springs has 37 years in, I believe him...
Anyone know where I can get those narrow profile spring bolt nuts? | | |
#55670 01/28/2006 4:15 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 46,
Are you talking about the center bolt? This goes through the springs, holds the pack together and centers the spring on the axle.
Stuart | | |
#55671 01/28/2006 4:58 AM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | John, was that at Kremer Spring up on the end of Robert St.? I've gotten the nuts there before in the past, but not lately. I think I do have a tap to clean up the threads in your old nuts if you wanna do that. | | |
#55672 01/28/2006 5:01 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | a-marc, Not the center bolt, but the main bolt...the big 11/16ths one that bolts the main to the frame, opposite end of the shackle...I never knew the nuts were "rare".
Barry,
Yep. I took my springs to Kremer. It has been 20+ years since they worked springs for me, but wow, they treated me very well. They rebuilt new mains on the front and provided all of the hardware except for the rear shackles. They did not have any that long. Not that money is everything, but I figured I saved $150 by going there instead of buying off the web.
Best part was talking with the guy when I picked them up. He knew some folks that I used to know..After 37 years, he had some good tips and secrets. I wish it had not been 4:45 on a friday when I was picking them up.
About the old nuts...I must confess...I pulled all of them off with an air impact wrench. Wanting that part of the truck to be new and safe, I (GASP) tossed three of the four. I might have saved the others, but I don't think I did. I was not planning on re-using them since the bolts were worn half thru. | | |
#55673 01/28/2006 6:01 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | You must've talked to Gib at Kremer? I've always liked dealing with local shops rather than mail order, but sometimes mail order is necessary.
I could probably dig up some nuts for you here, really they are just lock nuts as the bolt threads into the mount that's riveted to the frame. I could mail them down to you? | | |
#55674 01/28/2006 7:04 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Yep, Gib helped me out. Andy did the work, but had gone home for the day. Gib seemed like a very nice guy who knows his stuff.
Give me a couple of days to search for some new hardware. I am in need of another item too so I will E-mail you in a couple of days.
Thanks for the info. | | |
#55675 01/29/2006 6:08 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 46 in progress, the TRW number for the bolt and nut is 0348A, hope this helps. | | |
