| | | Forums66 Topics128,181 Posts1,057,189 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55648 01/27/2006 6:16 PM | Joined: May 2005 Posts: 9 Junior Member | | Junior Member Joined: May 2005 Posts: 9 | I need two new rear leaf springs. I'm considering purchasing new springs with 7 or 8 leaves. Are these going to be TOO stiff, and I'm not going for the "jacked-up" look. So ride height is also a consideration. What can I do to lower rear end a few inches to match lowered front end ( Clipped with Camaro ). I'm sure someone has experience. | | |
#55649 01/27/2006 9:15 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Bluenoser,
A spring shop could de-arch the springs you have. I think I saw another post that indicated your spring eyes were shot.
I have a spring shop making a new main spring for my fronts as we speak(type). It was cheaper than buying new ones. The spring shop will inspect the stack to make sure all of the rest are in good shape. Since I probably won't put on more a couple of thousand miles/year, I did not want to fork out $800 for new springs.
You might be able to get your old springs de-arched and also remove a couple of leafs while they rebuild the stack. A good spring guy should be able to tell you which ones can be safely removed. I did that on my last 41 too. | | |
