3 members (stlcardinalsguy, dunfire, Otto Skorzeny), 110 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
I'm just about to complete a front disc brake conversion on my 53 chev to go to a 5 on 4 3/4 bolt pattern. I would prefer to keep the stock hub caps. Does anyone know of a manufacturer, or another chevy car that I can get rims for the front from? Can the truck hubcaps cross over to 15" car rims from the 50's onwards? I'm running the stock 6 on 5 1/2 in the rear and could also use a new set of rims for that since my current rims are non-original and non-matching.
Cheers!
Marcus
wheel vintigues and others like stockton wheel can fix you up with about any thing but there if you want to pay the price .
Never take a sleeping pill and a laxative at the time.[/i]
1955 Chevy 3100
More pix on Photobucket
I just got mine in today from
http://www.rallyamerica.com/
I provided the measurements and they fabricated what I needed- reasonable cost, too.
Bluesharp- If you don't blow you suck....
'50 Chevy 3600 "Ernest"
70's jeep 6 luggers
Jim & Caroline
I tried to use the 49-52 passenger car wheels on my 56 when I did the disc conversion. They have a similar center section with clips like the truck but would not work. I subsequently purchased some after market wheels from Wheelsmith in Santa Ana, CA. They are dual pattern (4 3/4 & 4 1/2)commonly refered to as smoothies. They have a center that is similar to a rally wheel. He also took my stock caps and cut off the part that presses into the wheel and replaced it with a smaller ring. They have been on the truck for about 8 years.
Fred
Apprentice
Apprentice
chevy s10 older monte carlo 80 model regals and cutlas had the same bolt pattern even corvettes used it
Thanks Guys. Another supplier I found is Early Wheel, www.earlywheel.com, based out of California.
Cheers!
Marcus
When you did the disc brake swap did you go from a 6 lug to the 5 lug? I would like to do that but I thought you had to get different hubs and or whatever else...Can I just get a 5 lug kit and bolt it right up?
Mike
