1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 25 Apprentice | | Apprentice Joined: Jun 2009 Posts: 25 | I have a 52 chevy half ton (Just bought it yesterday so brand new newbie). I just have a quick question. How do you protect your door windows when you close the doors.
I know, some are going to say, don't slam it. But it appears that even when I try to go slowly, the window moves just enough for a potential break or crack. Is there some type of adjustement I can do ?
Let me know and thanks for your time. Peioa
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've never noticed that was an issue with my 1951. Maybe the weather stripping around your window glass is missing or needs replacement. It seems pretty tight in my truck. | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | just watch it when it is hot especially dont slam the door ,especially with the window half down . my mother did it to my ole man's 40 30 years ago and we still about it from him . | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I've never had an issue with it in my 54 3100 over the years, even during the times it was my daily driver. Samantha | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Virginiafiretruck's advice is on-the-money. He and Samantha most likely have good window seals. If your windows rattle, you should consider installing window weatherstrip and seals. Tim | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | +1 to virginiafiretruck
the u-shape track covers the entire travel of the window and helps to hold it in place- you will still get some side to side movement- but should not be enough to break it. the rubber rain trim that goes across the bottom of the window frame also helps when the window is open. all of the parts places will have them, I would check out links page. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If your glass does not have any chips around the edge it will have to strike a sharp, somewhat pointed object to break. Chips along the edge can be smoothed out with silicone carbide sand paper, the black stuff sold for sanding primer.
If your glass is loose in the channel replace the soft components that may have deteriorated over time. Cat whiskers and anti-rattle rubber are readily available but a PITA to replace. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Just to add my eperince with this, with new window guides the windows can be a bit stiff to move because they are so tight. Sometimes it takes a little silicon spray to ease the effort on the winder. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I will chime in here, like Czeckman and truckernix said. It is a real PITA to do. Look at all of the soft parts. If any of them look worn or are questionable replace them. I did my 52 last year, and you have to disassemble the whole door. Take pictures, measure, and don't throw anything away. You have to remove the vent glass assembly to get the window glass out. The shop manual is invalueable here. I purchased laminated glass locally and had it cut (take the old piece as a pattern) Tell them you want the edges beveled, also ask for the setting tape they just gave me the tape free gratis. It is a lot cheaper than buying glass online. If you do go with saftey glass it is thinner, and you either need thicker setting tape or have to use ureathane rubber setting caulk. One other note go slow and things will go well, also do a search and read up on the methodology. There is a wealth of tips and tricks in the archive. | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | I just did my doors. I replaced the door glass weatherstrip trim all around. (door channel, chrome beaded strip on the inside bottom of door, outside bottom door strip rubber, division post channel.) Right now my glass is tight and it will take a few up and downs before it loosens up even with silicon spray. But, I have no wobble or looseness. I purchased the parts from ClassicParts out of Kansas City. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The window seals that I got from Jim Carter and Chevy Duty (now Classic parts) were quite tight but they have loosened up nicely (no rattling and easy movement).
If you plan to paint your vehicle in the future, be careful using silicone lubricant. It is a substance that is hard to clean away and even a minute residue will contaminate most high-quality modern paints (and painting areas).
Tim
