8 members (TexasJim50, Otto Skorzeny, Greg_H, GusG, Lonnie, Nick in Manitou, J Lucas, moparguy), 102 guests, and 2 robots.
Topics128,089
Posts1,056,428
Members48,443
#555545 07/14/2009 2:08 PM
Hey guys. I tried the search function but I could not find a good answer to my question.
I have to have my 235 rebuilt out of my '50 3100 Chev. Now I could just start unbolting things and get out. But I was hoping someone could tell what might be the best way to get it out quickly with out disturbing too much.
Pull the hood and radiator?
or Pull the radiator and grill and leave the hood?
Pull the hood radiator and the grill?
Thanks I am just hoping to save a little time and keep it simple to put everything back together!
-Luke
"Pleasure in the job puts perfection in the work."
Story in The Gallery
Project pics on Photobucket
You are going to have to pull the hood and radiator. You will need the open space. The grille is up to you. I have gone so far as to take the entire front clip off a truck, but that was also because I was doing other work too. To keep it simple, pull the hood and radiator and leave the rest of the bodywork on.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
Thanks! Thats what I was thinking would be best to allow room for the hoist. Then I wont have to worry about alligning fenders and such. smile
-Luke
It can be done with the hood left in place. For me removing/replacing the clip is much easier than aligning a hood.
http://rides.webshots.com/photo/1377804259023244788ucjcVI
You Tube
I am with Curt, I have always removed the front clip. Leave the hood.
So would pull the tranny with the motor or leave it in the truck?
-Luke
Curt- I looked at your pics! Very nice looking motor. I would like mine to look that good once it is ready to go back in the truck... I have an oil filter to install and like how you did yours. Everything is very neat and tidy. I know I am getting a little ahead of my self but what is the correct color for this engine?
-Luke
Correct engine color is light gray and if you do a search for engine paint some codes should pop up. Three speed trannys come out easily left attached but my understanding is that 4 speeds have some complications and are best separated for removal/install. Have fun.
You Tube
Y
Y Offline
with my 4 speed I had to separate the two so it would clear the cab coming out of the truck- if it is a three speed- I would think you could get them out together. I would follow the shop manual.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
I recently pulled out my 235. I pulled the motor and 4 speed manual tranny connected, with no issues whatsoever. All I did was take the hood off and radiator, and all the little stuff of course.
Just make sure you have a good hoist because that inline 6 along with that tranny is a bit of a beast.
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
Y
Y Offline
on my truck I when I tried to remove the engine and trans together I had a cross member that the engine mouted to that prevented me from pulling both without taking the cab loose from the frame and jacking it up.
Rent a good hoist, preferably one with the in/out ability. It only cost a few bucks more and makes the job a whole lot easier.
~Jim
If it is a four speed,you may have to remove the shifter.
My truck (49 chevy 216) required me to remove shifter and jack cab slightly to remove.
Now I am preparing to reinstall and I really wish they had made that crossmember removable like the rear.
Hate to unbolt cab again,afraid of twisting,but the tranny without the shifter is 12 inches and the opening is 10 inches.
just-a-hacker
'49 3100 before '99
I have a good hoist. It does not however have in/out with out pulling an adjustment pin. It does roll pretty nice with some weight on it though.
I have a 4 speed and I still have not decided if I want to pull it with the motor... I dont think I have a cross member in the way which should ease in pulling everything out should I go that route.
-Luke
bigblue,
You might want to look again,the back of my bellhousing mounts to a stationary crossmember and the tranny has a mount to a removable crossmember.
It's that stationary crossmember thats the problem.
Just-a-hacker
just-a-hacker
'49 3100 before '99
In my case, I removed the clip and cab (many times)....after that, r&r'ing the motor was easy.
Well I got a replacement 235 from colletsbro that I should be picking up this weekend. Thanks Brian! I also have the old 235 pulled out and I will be working on cleaning up the engine bay.
I'll be needing new engine mounts because my old rubber ones in the rear are pretty much shot! Anyone know a good source for them?
Pulling the motor was pretty straight forward. I removed the hood and disconnected every thing. I had the head pulled to I didnt have to remove the core support of shroud to get it out. But I did remove them after I got it out because there is no way the new motor will go in with the head on and the fan shroud and core support in place.
Hopefully I'll be able to start putting things back together on sunday if the weather is not too bad.
Couple of pics: http://s433.photobucket.com/albums/qq59/BigblueL29/50%20Chevy/
-Luke
' Offline
I have a later truck ('66) so I don't know if pulling an engine is the same for mine as yours but... When I pulled the engine from my donor truck it was attached to a 3 speed overdrive trans. I left them together and they came out without a problem. My truck has a 4 speed in it, and I decided to go with that instead of the 3 speed. Shortly after I put the engine in my clutch went out, so the engine had to come back out. With the 4 speed, I had to pull the engine seperate. Then I pulled the trans out because I was having problems getting the engine to mate to the trans with the other clutch. But to get the 4 speed out I had to pull the shifter, then unbolt the bellhousing from the trans. The bellhousing then came out easy, and the trans came back and out under the truck. I had a permanent crossmember in the way of the whole thing coming out it one piece...
as far as what to take off, I think having the whole front clip off is the easiest. Hope you get it figured out, good luck.
Riding in the Passing Lane
Leave the trans. in.
1972 Chevy c10 Cheyenne Super
Yup I left the trans in place. I have been working on getting all the little parts cleaned and painted. The engine bay is done and looks great. 95% of my motor parts are painted and ready to go. Tonight I have a couple of buddies coming over to help me get the motor back in place and start connecting things back up.
I am pumped. I'll try to link up a few more pics when I get it in.
-Luke
Well my buddies flaked on me this weekend. So I did not get the motor put in. Hopefully they can make it this weekend, but then again it will be halloween so we'll see.
Anyone want to lend a hand that happens to be in the Twin Cities area??
-Luke
all one has to do before removal of the hood is to drill a 1/8" hole through the hinge on eiher side and when you put it back on just insert a 1/8 pin in the holes to line it up
ron
pull the hood, pull the front clip, pull the unit as an assembly.
Take Ron's advice above on any hinge (hood, door, etc.) as that is how its done for restorations when you build the vehicle complete, then tear it down for paint.
Well I pulled the hood and the front core support and left the fenders and grill in place. I also have the new motor back in and now I just need to work away on hooking everything back up and running new hard fuel lines, plumbing the oil filter, replace the heater hoses, and fluids etc.. but the hard part is done!
-Luke
