Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#555331 07/13/2009 8:55 PM
got a guy on craiglist near me that has a quote "55-64 chevy rear end member 3:36 gear non posi" this may be out of a car, don't know, but would this fit in a 55 2nd series and have everything bolt back-up, axles and stuf. I don't know jack s---- about rear ends. Thanks....
If it's from a passenger car, whcih is what it sounds like, it will not work in a truck. The Passenger rearend was the same from '55-'64, and has an oval shape to the 3rd member and no removable cover on the housing (like a 9" ford. It also has pressed wheel bearings. The Truck diff, however, is only the same from '55-'62 (some '63s may have this rearend as well), has a removable cover, C-clip style axle retention, and the 3rd member and cover are round.
If you can get a pic of it, or get the codes, we can ID it for you before you make any purchase.
Bill Burmeister
