3 members (ranchojuan, baldeagle, Hotrod Lincoln), 31 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#555283 07/13/2009 6:43 PM
the int. to head alignment bushings were missing on my 235 56 eng. I could not find new or used ones this is what I did to make new ones. I took 1.5" brass freeze plugs drilled out the center with a hole saw and deburred with a file they were a perfect fit both ID & OD
You Tube
Curt B. #555360 07/13/2009 10:16 PM
These are hard to source parts for sure so both of these tips are good to have.
Thanks.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #555361 07/13/2009 10:28 PM
I am a firm believer of making your own, however, the alignment rings are readily available and not too expensive (and, no special tools are needed):
Jim Carter
Classic Parts of America 53 and earlier and 54 and later
