Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Svcattle, baldeagle), 145 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
#555010 07/12/2009 10:14 PM
Anuther dum question. How tall are the COE`s to the top of the cab (8.25-20 tires). My heated workshop garage door height is 96" even. Maybe if I let the air out of the tires or get out the chainsaw? Or take the cab off?
Thanks again, John
John Drabik #555015 07/12/2009 10:34 PM
My '53 Chevy 2 ton COE with 9.00 X 20 tires was 96in." from the ground to the top of the cab.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #555115 07/13/2009 3:05 AM
My '50 Chevy 2 ton COE, model 5700, had 8.25 x 20 tires and was one inch shy of the top of my 8' door. I researched this very carefully and when I arrived with my new prize, discovered that I had forgotten about those tall cab marker lights!! Had to raise the door header, get new garage door panel, etc. So don't forget about those lights if you have them. And if you have them, you gotta keep them, they are part of the character of the truck.
Also, I would not recommend letting air out of the tires if you have split rims, could be dangerous.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
