0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | I need a picture of the correct firing order for a 57" 235 | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Joes1952,
I'm not sure about a picture, but any sequence in clockwise rotation of wires (around the cap) that equates to 1-5-3-6-2-4 will get you what you want. #1 can be anywhere you heart desires, unless you are a purist. Cylinder # 1 is right up front next to the fan.
Stuart | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | The distributor cap tower that begins the sequence isn't important, but it must be the one where the rotor points with #1 cylinder on top of the compression stroke. Pull the #1 spark plug, put your thumb over the hole, and have someone tap the starter until you feel compression. The cap tower the rotor points toward when compression pops your thumb out of the hole needs to be #1. Follow in a clockwise direction looking at the top of the cap with 5-3-6-2-4. Don't forget to reinstall #1 plug! Jerry
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | is this the same for a '49 216 ?
?? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy just-a-hacker, yes it is. | | |
