5 members (Denny Graham, Steelonsteel, 66flea, treegrower, Otto Skorzeny), 52 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#554855 07/12/2009 6:42 AM
I need a picture of the correct firing order for a 57" 235
joes1952 #554858 07/12/2009 6:50 AM
Joes1952,
I'm not sure about a picture, but any sequence in clockwise rotation of wires (around the cap) that equates to 1-5-3-6-2-4 will get you what you want. #1 can be anywhere you heart desires, unless you are a purist. Cylinder # 1 is right up front next to the fan.
Stuart
joes1952 #554921 07/12/2009 3:58 PM
H Online: Content
The distributor cap tower that begins the sequence isn't important, but it must be the one where the rotor points with #1 cylinder on top of the compression stroke. Pull the #1 spark plug, put your thumb over the hole, and have someone tap the starter until you feel compression. The cap tower the rotor points toward when compression pops your thumb out of the hole needs to be #1. Follow in a clockwise direction looking at the top of the cap with 5-3-6-2-4. Don't forget to reinstall #1 plug!
is this the same for a '49 216 ?
just-a-hacker
'49 3100 before '99
3B Offline
Hy just-a-hacker, yes it is.
