1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#554820 07/12/2009 2:18 AM
I have finally made my transmission decision. I will be adding a TH350 behind my 250. I have the factory style radiator for a manual three on the tree. Is there a kit available where I can just add a transmission cooler without getting a different radiator?
Jegs and Summit sells these. Type in "Transmission Cooler" in their search box. You might also want to consider plumbing in a Trans. Temperature gauge while you are it.
http://www.jegs.com
http://www.summitracing.com
Thanks, I see one that doesn't look too pricey. I also thin k I see how they fasten. There are some thingies that look like sip ties with a cap on the end. I assume they go thru the original radiator and then get zipped up.
drawtite makes some user friendly and decent priced unit's .http://www.draw-tite.com/ you can see the zip tie mount ties that goo through the radiator fins .
