| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I have finally made my transmission decision. I will be adding a TH350 behind my 250. I have the factory style radiator for a manual three on the tree. Is there a kit available where I can just add a transmission cooler without getting a different radiator? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Jegs and Summit sells these. Type in "Transmission Cooler" in their search box. You might also want to consider plumbing in a Trans. Temperature gauge while you are it. http://www.jegs.comhttp://www.summitracing.com
| | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Thanks, I see one that doesn't look too pricey. I also thin k I see how they fasten. There are some thingies that look like sip ties with a cap on the end. I assume they go thru the original radiator and then get zipped up. | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | drawtite makes some user friendly and decent priced unit's .http://www.draw-tite.com/ you can see the zip tie mount ties that goo through the radiator fins . | | |
