| | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey guys, Just installed a 1973, 10bolt(cutlass) under my 1948 1/2t and am wondering what to do about the brake cables that mount to the frame.I have new cables for the cutless brake but its about 3"to short to work with the original bracket. So what did yaull do?
I removed the lever action shocks and went with gas tubes so now I need to figure where to mount the top mount. The bottom mounted right under the leaf spring and holds the bottom of the shock between the frame and the tire,but where I need to mount the top is questionable. Any body done this? Thanx, mike
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If You are going to use the mounts for AD truck than the top mounts that You can get from any of the venders is at a 60 degree from the bottom mount angled to the front of the frame if You need a pic I will post it .
Pete | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey THANX Pete! I have the mounts but wasnt sure what O to set them at. Does this also include the back ones?
mike | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Yes the rear and front are the same , use the top straight part of the frame and draw a line down to the rear mts. at 60 degrees toward the front on both front and rear and You got it , good luck and have fun .
Pete | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | www.inlinetube.com can make you a set of emergency brake cables. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | OK Pete, 60degs. Thank Ya
Thanx bowtietim, I'll look them up
mike
