1 members (klhansen),
90
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | I just got my Rochester B, and did a mock install just to adjust the idle and mix. It runs great, but I can't figure out how to install the choke cable. I see where the cable terminates, in the brass block with the set screw, but can't find where the cable clamps to. Also where does the throttle return spring go? I don't see any obvious location. carb linkage pic 1 carb linkage pic 2 | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | You have to find the correct combination cable clamp that attaches to the carb under the rear right screw (as it sits on the carb) which is one of the four screws that holds the top on the carb. The clamp has two places to clamp both cables to it so it will function on the carb. You just need use one carb for choking and throttling.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Like Tex. says there should be a bracket under one of the screws that hold the air horn on. Some have a bracket for one cable & some have a bracket that supports a throttle cable also. The spring goes on a hook on the verticle rod under the manifold down to a bracket under an oil pan bolt. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | Thanks guys. I only have one cable (choke) and the throttle rod going to the carb. I don't have either the choke cable/bracket or the spring bracket down at the oil pan. What do they look like and where can I find them? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put an ad in the parts wanted section. There are plenty of them around. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The Bracket for choke & throttle cables. Another pic
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Once you click on the following, there are a couple more pics. Hopefully they will help. Choke & throttle hookup
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | not to hijack the post - but what is the second cable for? I know the choke cable, but what is the other one? Does it need to be hooked up? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Farmer - 2nd cable is the hand throttle, not needed if you don't want it
Bill | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Thanks - Just took a close look & found mine is rusted up - nice to know there is a red-neck cruise control on this one! | | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | I will use this diagram when I replace my Carter YF to a Rochester. Thank you
Kevin 235 1/2Ton 5window
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | | | | Joined: Feb 2015 Posts: 11 New Guy | | New Guy Joined: Feb 2015 Posts: 11 | I've been looking for this and I've got the book in my lap. lol, just kept passing it. | | |
