| | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Here's a tip that I thought I'd pass along here in the General Forum so more would see it... I've had this ongoing problem with my keys dangling from the ignition and scratching the dash. Yes, I know I could just have the truck key on a clip but I don't.... Well, I came across a clear laminate that's actually designed to protect the faces of electronic gizmos like blackberrys, cell phones, etc. I adhered it to the dash area right below my ignition and * voila * no more scratches! It's clear and has a gloss sheen to it but it's hard to tell that it's there. You can find out more here: www.BestSkinsEver.com I ordered Item No. 1021 - click on "DIY Custom Skins" in the left side menu bar. It cost $6.99 + $2.00 shipping.
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Nice tip LB. That could maybe work anywhere there is constant or repeated rubbing/contact from arms or hands. thanks. Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Howdy,
There used to be "scratch guard" things that went behind the ignition switch and followed the contour of the dash down a bit. I don't know if they were a factory or after market thing. They disappeared when keys went to the steering column. I had a 1953 Merc that had one. This is just some of the worthless knowledge that is running around in my head.
Best wishes,
Les | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Les, all of us suffer from the WKS 'worthless knowledge syndrome'... but it's important to someone somewhere! | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I don't mind the scratches from my keyring, it just means it's driven.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
