7 members (Bill Hanlon, greenie-reddy, Nick in Manitou, Gdads51, Forty9, 2 invisible), 151 guests, and 1 robot.
Topics128,198
Posts1,057,272
Members48,466
#552344 07/03/2009 3:59 PM
I working on a 63 GMC 4x4 and Im going to move the fuel tank from inside the cab to the rear does anyone know the best tank to use dont want it to hang down to low. Any info would be a help!
the ones for the chevys are basicly the suburban tank. i have one poly tank and one steel- don't know much difference.
Got ya covered! Last winter I installed a 49-52 Chevrolet passenger car fuel tank in the rear frame of my 65 C10 Shortbed.
Check out the following link and also check out my "Webshots" photos link at the bottom of this page for a bunch of pictures.
This conversion requires welding. It also involves trimming of the bottom frame rail inner lip. This needs to be done to allow the gas tank to drop out from the bottom of the truck. As the pictures show I removed the bed from the truck to do the work, this is a necessity for access. Basically if you have a Sawzall and a welder (or access to a buddy with these) you can do this conversion.
Let me know if I can be of help.
H.A.M.B. website thread with pictures and link to vendors for the parts:
http://www.jalopyjournal.com/forum/showthread.php?t=324929
Stove bolt thread:
https://www.stovebolt.com/ubbthread...=Hot+Rod+John&Search=true#Post492905
Link to Tanks Inc. for the 49-52 Chevy Passenger Car Tank:
https://www.tanksinc.com/index.cfm/...=799/category_id=63/mode=prod/prd799.htm
Last edited by Gdads51; 02/08/2025 11:24 PM. Reason: update link to current P car tank ID
Apprentice
Apprentice
anyway to move them in a 62 short box? I would really like to get it out of my cab.
Spanky,
Your '62 should be the same as my '65 in regards to the rear suspension and location of the new tank. Therefore the parts and methods I described should work for you also.
Apprentice
Apprentice
Classic Truck parts sells a full kit(tank,sender, brackets, etc) for locating the tank in the back for about $200.I have a 63 panel which comes with the tank in the back under the bed (wrotted of course) so this kit will be my option. You really don't want to use a panel/subrb tank because theyre shaped to fit the spare therefore cutting down on your tanks capacity.
[email protected]
FYI: The tank in the Classic Truck kit will hang down low and be visible from the side the truck. I know of a few guys who used this set-up and were dissapointed because of this.
whats the matter with everyone. YA dont like the smell of gas as your'e goin down the road?
"you can't fix stupid"
That's not the problem Cap'n, its the cigarette coming back over my shoulder as I try to toss it out the window that bothers me......LOL
1961 Chevy C10 Stepside
On my web site
Apprentice
Apprentice
Its nice to know someone can still afford to smoke.
Ray K.
I had to give it up RayK64FS, so I could afford to put my fuel tank out back.!!!! LOL
On my web site
I used a 15 gal aluminum tank I got from Summit. You can see it from the rear but hardly visible from the sides. It doesn't cause me any lost sleep.
