1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
#552670 07/04/2009 10:19 PM
Having never lowered a truck , i found myself researching how this is done correctly , nothing to technical just want to drop my truck 2'' maybe 3'' inches while trying to keep my truck as original as possible , anyone got any suggestions or information
that could give me a hand...
A dropped front axle, or monoleaf front springs. Blocks in the rear.
Just as OldSub said and just be prepaired for some additional work re. the dropped axle: steering arms will need bending to miss the springs, and you may have some bump steer to tend to.
I also went with tube shocks and radials, it never ends.
1946 1/2-Ton Chevy
a few of the guys here on stovebolt, including me, went with a dropped front axle from Sid, here at droppedaxles.com
http://droppedaxles.com/
simple swap out, and Sid is a grat guy to do business with.
i went with a 3 inch dropped front, and also took out 1 leaf, and in the rear i just took out 4 of the original 7 leafs, and installed some longer rear shackles.
good luck....
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
I understand you can take a set of front spring mounts and replace your rear spring mounts with them to lower you rear a bit. Looking at it alls it would take is drilling new holes to mount the spring mounts. I have not tried this, just read about it in a artical from fat man fabrication
Jason
Here is how to article my friend Jeff wrote for me. We dropped his truck one Saturday.
http://droppedaxles.com/TECH_ARTICLES.html#TXTOBJ7D9416E352E1C51
I went with monoleafs from Durant Springs. Rides great and easy install. Dropped the truck approx 3 inches. Good luck
