| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 19 New Guy | | New Guy Joined: Nov 2007 Posts: 19 | I found a big bolt (actually a fire bolt) I want to purchase. Can someone answer some basic questions:
1. Is $3300 a reasonable price for a '65 C60 truck in very good condition?
2. What is payload and towing capacity?
3. Where to find a shop and/or owners manual?
4. Anything to look for (gotchas) before completing the transaction? 5. Does a C60 require a CDL?
| | | | | Joined: Jan 2009 Posts: 24 Apprentice | | Apprentice Joined: Jan 2009 Posts: 24 | c60 is typicaly 18-26,000 lbs loaded.
26,000 is the cut off for c class license, typicaly drivers license. you shouldnt need a cdl to buy or drive it, but it may have air brakes and that can require a endorsement on you license, non commercial w/air. because its a a fire truck you may need to have a non/comm B class w/air.
56 2 ton, and never enough time.
| | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | $3300 is a great price on a firetruck. You shouldn't have the problems that a farm/contractor truck would have with rust and alot of wear. Make sure you check the brakes thoroughly!! By buying such a truck you're way ahead of the game. You should be fine without a CDL. Shop and owners manuals are easily found on ebay.
Hope to see some pictures if you do make the purchase!
JAMES
| | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | Are you going to leave it as a firetruck? Just curious. | | |
