2 members (Otto Skorzeny, Gray_Ghost), 131 guests, and 1 robot.
Topics128,080
Posts1,056,063
Members48,433
Big Bolt Forum Co-moderator
I took my leaf springs apart, cleaned them up and painted them. Have new hardware and was wondering if there should be some lubrication between the leaves as I put them back together? The manual says lubrication is not done other than "time of assembly". Should I put something like Never-seize on them, or just a good grease?
1948 Chevy 2-Ton
3B Offline
Hy Super55, a light greasing should suffice.
I used the teflon inserts between each leaf. Bought from Jim Carters in a roll. I have assembled the springs but, not on the rd. yet. It looks good and will not pick up road dust and dirt like grease will.
Good Luck.
Mike
I don't think you want to put grease between the leaves. You need to have some friction there inorder for the spring to work as it was designed. Without friction any weight put on the spring is just going to flatten it out. Any way that is just my opinion Joe B.
Call a spring shop or two and ask what they recommend, then let us know.
I'm thinking something should be used once when you put them back together the first time, but not much.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
back in the day they were just oiled
ron
Grigg,
I am going to stop by a spring shop. I can't find an auto parts nearby that has the centre spring bolt. I'll ask when I go in.
1948 Chevy 2-Ton
Most of the old service manuals call for a thin layer of graphite grease between leaves when assembling a stack of leaves, and then no further lubrication. Springs depended on friction between leaves for load carrying capacity.
The guy at the spring shop said to leave them dry.
1948 Chevy 2-Ton
Did you find your spring center bolts?
If your auto parts store doesn't think they can get them ask if they have Dorman products, I've seen spring center bolts on the shelf in Dorman boxes at my local auto parts stores.
Grigg
---All pictures---
I got the centre bolts and the rollers that go on the shackle bolts at the spring shop.
1948 Chevy 2-Ton
Good,
But what are "the rollers that go on the shackle bolts"?
Grigg
---All pictures---
Where the three bolts that go through the three u-brackets on each leaf, there is a tube that the bolt goes through. I guess as the leaves flatten it makes the pipe roll rather than wear on the bolts.
1948 Chevy 2-Ton
Sounds like a spacer for the spring clips, lets you tighten the bolt tight without squeezing the sides of the springs?
Grigg
---All pictures---
