2 members (Gray_Ghost, RLB),
194
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I took my leaf springs apart, cleaned them up and painted them. Have new hardware and was wondering if there should be some lubrication between the leaves as I put them back together? The manual says lubrication is not done other than "time of assembly". Should I put something like Never-seize on them, or just a good grease? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Super55, a light greasing should suffice. | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | I used the teflon inserts between each leaf. Bought from Jim Carters in a roll. I have assembled the springs but, not on the rd. yet. It looks good and will not pick up road dust and dirt like grease will. Good Luck. Mike | | | | | Joined: Mar 2008 Posts: 14 New Guy | | New Guy Joined: Mar 2008 Posts: 14 | I don't think you want to put grease between the leaves. You need to have some friction there inorder for the spring to work as it was designed. Without friction any weight put on the spring is just going to flatten it out. Any way that is just my opinion Joe B. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Call a spring shop or two and ask what they recommend, then let us know.
I'm thinking something should be used once when you put them back together the first time, but not much.
Grigg | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | back in the day they were just oiled ron | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Grigg, I am going to stop by a spring shop. I can't find an auto parts nearby that has the centre spring bolt. I'll ask when I go in.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Most of the old service manuals call for a thin layer of graphite grease between leaves when assembling a stack of leaves, and then no further lubrication. Springs depended on friction between leaves for load carrying capacity. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | The guy at the spring shop said to leave them dry. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Did you find your spring center bolts? If your auto parts store doesn't think they can get them ask if they have Dorman products, I've seen spring center bolts on the shelf in Dorman boxes at my local auto parts stores.
Grigg | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I got the centre bolts and the rollers that go on the shackle bolts at the spring shop. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I got the centre bolts and the rollers that go on the shackle bolts at the spring shop. Good, But what are "the rollers that go on the shackle bolts"? Grigg | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Where the three bolts that go through the three u-brackets on each leaf, there is a tube that the bolt goes through. I guess as the leaves flatten it makes the pipe roll rather than wear on the bolts. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds like a spacer for the spring clips, lets you tighten the bolt tight without squeezing the sides of the springs?
Grigg | | |
