3 members (GIJOE298, Peggy M, 1 invisible),
123
Mod | | | Forums66 Topics128,078 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | I have a buddy who is looking for a "shift lever assembly" but is not sure just what transmission he has.
The casting numbers are: side: GM465452 On the top: GM18, and below that is: 3901131
I would appreciate any help in identifying this transmission or finding out where I can get this information. He called Chevrolet and they played brain dead. Thanks for any help. williejoebob | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what year truck is it?
3 speed or 4?
column lever assembly or top loader lever?
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | boy, we all jumped on this one at the same time. I was posting just to bring it back up so we could help. | | | | | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | I'll do my best to get as much information as I can. Thanks for the interest. | | | | | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | Okay, here's what I know now: 4 speed with floor shift. He needs the shift lever and the "top cover" of the transmission that the shift lever goes in (and the connecting ball and pins from lever to top of the transmission). Apparently, someone just stole the shift lever by breaking it off. I hope i'm making sense.
Trans came out of an 87 chev 1 ton dually, but not sure original to that truck.
casting numbers: went to Ebay---465462 same on both; his--3901131 vs. Ebay 3901127.
plate on side has: 59000 E 67044;(not sure if maybe added by shop that rebuilt trans earlier);
His also has F217 on top below 3901131.
Working on photos. Is the pan the top of the trans? Thanks again.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd just take some measurements of the cover bolt arrangement and start walkin the wrecking yards, likely any 80's top loader will have the identical top and lever regardless of minor model changes
pan ID's are bottom of automatics, don't apply here
Bill | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | It should be an SM465. Common from late 60's to early 90's. | | | | | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | Thanks to all.
Williejoebob | | |
