0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#55200 01/18/2006 6:09 PM
I'm ready to put a 250 back in my truck. After just having it rebuilt, I'm not sure I want o loosen and use the head bolts for pick points. Any suggestions on where to hook the chain hoist?
Or....is it perfectly alright to use the head bolts?
#55201 01/18/2006 6:14 PM
manifold or maybe bellhousing at rear, water pump at front?
#55202 01/19/2006 12:01 AM
Riding in the Passing Lane
Wrap a chain around the intake manifold towards the rear & put a bolt in the coil mounting bolt hole. Balances out real good.
1972 Chevy c10 Cheyenne Super
#55203 01/19/2006 1:47 AM
Just want to thank all of you for this information. I will be removing my 292 this summer & was wondering what was the best way to do it.
#55204 01/19/2006 3:50 AM
Do you mean it says remove rockers or rocker cover?
#55205 01/19/2006 4:41 AM
Jeff,
Any advice on the break in procedure once installed and started?
#55206 01/19/2006 5:35 AM
I am with iowa trucks on this one. I have the front end just about undid on my 72 and as soon as I get the hvac sorted out I'll slide the driveline in.
