| | | Forums66 Topics128,012 Posts1,055,316 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55200 01/18/2006 6:09 PM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I'm ready to put a 250 back in my truck. After just having it rebuilt, I'm not sure I want o loosen and use the head bolts for pick points. Any suggestions on where to hook the chain hoist?
Or....is it perfectly alright to use the head bolts? | | |
#55201 01/18/2006 6:14 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | manifold or maybe bellhousing at rear, water pump at front?
Bill | | |
#55202 01/19/2006 12:01 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Wrap a chain around the intake manifold towards the rear & put a bolt in the coil mounting bolt hole. Balances out real good. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#55203 01/19/2006 1:47 AM | Joined: Dec 2005 Posts: 4 New Guy | | New Guy Joined: Dec 2005 Posts: 4 | Just want to thank all of you for this information. I will be removing my 292 this summer & was wondering what was the best way to do it. | | |
#55204 01/19/2006 3:50 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Do you mean it says remove rockers or rocker cover? | | |
#55205 01/19/2006 4:41 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Jeff,
Any advice on the break in procedure once installed and started? | | |
#55206 01/19/2006 5:35 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I am with iowa trucks on this one. I have the front end just about undid on my 72 and as soon as I get the hvac sorted out I'll slide the driveline in. | | |
