6 members (baldeagle, Shade Baby, 46 Texaco, cmayna, Peggy M, 1 invisible), 68 guests, and 7 robots.
Topics128,018
Posts1,055,342
Members48,419
#551406 07/01/2009 1:48 AM
I have a 1951 Chevy fleetline. I am swapping the original locked up 235 with a 58 235. I am using the 51 flywheel, bell housing and starter. The starter will not turn the motor (the motor does turn by hand). The starter does turn with voltage applied on the workbench. Seems like there is not enough torque on the starter? Is the starter bad? Is there a way I can fix it?
weltertm #551743 07/02/2009 12:25 AM
Did You check the battery to make sure it is charged , out of the truck it only takes minimum amps to turn starter when cranking engine it will take alot more also check cables , good ground all that stuff .
Pete
Pete52 #551925 07/02/2009 11:45 AM
Pete52 has it right:
The place to begin when experiencing slow cranking or no cranking is the positive battery cable and the negative battery cables and grounding straps/cables. They should be at least (most?) 2 gauge, but 1 gauge or 0 gauge or 00 gauge are preferred. Most replacement battery cables were/are 4 gauge (appropriate for a 12v system).
Second: weak battery
Third: weak starter
