3 members (Joe H, Gdads51, UtahYork), 99 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#551206 06/30/2009 2:40 PM
I'm having a little problem with the windshield wipers. While drving and idling I turn the switch for the wipers and they only move a little and then stop completly. Not sure if I have a leak in the vacuum or something else? Can anyone help? I have a 51 2 Ton Dump 6100
beacon #551223 06/30/2009 3:21 PM
Beacon,
IM FAR FROM AN EXPERT on the vacume wipers but sure sounds like you need a rebuild on the wiper motors or at minimum some lubin up of all the movin parts, the vacume wipers need to be able to move freely.
Im sure the Elders will chime in an guide ya on this fix.
1952 Chevy Shortbed
Photos in Photobucket
beacon #551227 06/30/2009 3:39 PM
I'd start off by replacing the rubber vacuum hose that runs from the manifold to the wiper motor. Putting some oil on the linkage under the dash helps. What's your vacuum at idle? It should be around 19 ish inches. If your vacuum is good, and you have no leaks, its time for a vacuum motor rebuild. You can send it to Ficken wiper service. That's what I did with mine. It works as new now. It does cost more than buying one from one of the vendors, but, he replaces the paddle and stuff. Plus, it'll last forever afterwards.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Can you send me the contact info for Ficken's? What size hose is on that piece for replacement? Thanks
beacon #551238 06/30/2009 4:29 PM
Moderated by  ndkid275, Phak1
