3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
#551196 06/30/2009 1:59 PM
The cutoff valve on the bottom of my '46 Two Ton's underseat gas tank has started dripping. It looks like the cutoff valve may be welded into the tank, or it just may be that there is a crud buildup around it. Anyway, I am concerned about putting a wrench on it and forcing the issue. Anybody have any experience with changing out this valve? Also, I can't seem to find the valve listed in any of the usual parts supplier catalogs.
The valve should be threaded onto a 1/4" nipple that is threaded into the tank... at least mine was. When I tried to remove the valve, the nipple broke off in the tank. I used a drill to remove the broken nipple and replaced it with a new one I got at the local hardware store in the plumbing section. Not much can go wrong with the valve, so the nipple is probably your problem.
Good luck, George.
MIne was pretty cruddy, Soaked it with penatrating fliud and wire brushed it a lot. Eventually it came out.
