2 members (DaveV, Napco Man),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 38 | I'm having a little problem with the windshield wipers. While drving and idling I turn the switch for the wipers and they only move a little and then stop completly. Not sure if I have a leak in the vacuum or something else? Can anyone help? I have a 51 2 Ton Dump 6100
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Beacon, IM FAR FROM AN EXPERT on the vacume wipers but sure sounds like you need a rebuild on the wiper motors or at minimum some lubin up of all the movin parts, the vacume wipers need to be able to move freely. Im sure the Elders will chime in an guide ya on this fix. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'd start off by replacing the rubber vacuum hose that runs from the manifold to the wiper motor. Putting some oil on the linkage under the dash helps. What's your vacuum at idle? It should be around 19 ish inches. If your vacuum is good, and you have no leaks, its time for a vacuum motor rebuild. You can send it to Ficken wiper service. That's what I did with mine. It works as new now. It does cost more than buying one from one of the vendors, but, he replaces the paddle and stuff. Plus, it'll last forever afterwards.
| | | | | Joined: Feb 2009 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 38 | Can you send me the contact info for Ficken's? What size hose is on that piece for replacement? Thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | |
