| | | Forums66 Topics128,195 Posts1,057,372 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 31 | I don't have new seals on bottom of door's of my 52 to make a gestimate and see where they strike rocker panel. My doors are nice and level with rocker and have right gaps front and back. Should bottom of door be even with bottom of rocker or hang below just a bit? I understand there is probably not an exact measurement here and this might vary from truck to truck. Thanks in advance.
Doug | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If your doors have a good gap along the top, front and rear and align with the beltline the position in relation to the sill or rocker panel is good. I believe there are pictures of where to install the bottom seals in the Factory Assembly Manual. | | | | | Joined: Oct 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 83 | Nowadays there is a spec. for gaps between doors, hoods, fenders, quater panels; usually just a few MMs. BAck then I beleaive it was "an equal-distance" all around, which is what everybody uses anyway.
1999 GMC Yukon 1957 GMC 100 Panel
