0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 8 Member | | Member Joined: Jan 2003 Posts: 8 | Stats: '62 Chevy C-10. Inline 6. Four on the floor. Granny low. One barrel carb. Distributor is back between the 4th and 5th spark plugs. Has the long inspection plate on the distributor side of the engine.
The parts guy at the Chevy dealership says the long inspection plate means it's a 292, but I saw somewhere on the net that the 292 wasn't put into pickups until '63.
What do I check to know for sure?
P.S. We put 292 plugs into it as part of a tune-up and noticed that the threads were longer on the plugs we installed than on the plugs we removed. I don't know if that's important. Thanks in advance for any ideas.
Christ Jesus came into the world to save sinners -1 Timothy 1:15
| | | | | Joined: Jan 2003 Posts: 8 Member | | Member Joined: Jan 2003 Posts: 8 | JunkYardFrog asking.... (Still locked in this 1962 time vortex!)
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Try the casting #'s section at inliners.org http://www.inliners.org/ | | | | | Joined: Jan 2003 Posts: 8 Member | | Member Joined: Jan 2003 Posts: 8 |
| | | | | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | The 235 survived through 1962. The Chevy parts guy should know better. If it's a single long pushrod cover, then it's not one of the later motors - they all used two smaller covers. You've probably ot a 235, but check the casting number on the block to be sure. And if the head casting number ends in "848" or "850" then it's either a 235 or 261. | | |
#5505 01/06/2003 10:18 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | 1962,
You have either a 235 or 261; the center location of the distributor (between cylinders #3 & #4) confirms this.
ALL 194/230/250/292 engines have the distributor at the front of the engine, between cylinders #1 & #2.
As for the "long" inspection cover (called a "tappet cover" or "side cover") on the side of the engine identifying it as a 292, I think what your buddy was referring to is that while the 230/250/292 engines are basically the same, the 292 has a taller block (longer stroke), and therefore, the 292 side pan is higher than on the 230/250.
Check the casting #s as described in preceeding posts to see if you engine is 235 or 261; externally they're the same size, differing only in factory paint color.
Good luck!
Frank McMullen
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | 235 or 261. the 292 had two side tappet covers that were taller than the 194-230-250.
#5507 01/07/2003 10:27 PM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello 1962. i am worried about those longer plugs that you installed because they might bump into a valve or piston. i say this without actually going out to look at one of the heads i have, but i do remember that some of the chevy six plugs are alot longer than others. it would be too bad to ruin the engine because the plugs were the wrong application.good luck.
our garage is a non-profit organization
| | | | | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by garyg: hello 1962. i am worried about those longer plugs that you installed because they might bump into a valve or piston. i say this without actually going out to look at one of the heads i have, but i do remember that some of the chevy six plugs are alot longer than others. it would be too bad to ruin the engine because the plugs were the wrong application.good luck. Yeah. Thanks. I've been thinking about that too.... I figure, it's running better than it was before, so no pistons or valves have hit the plugs. Still, since I now know I have one of the smaller engines, I should put in the correct plugs. Plus, the first plugs we pulled out were horribly black so I want to check these plugs and see how bad they look after a few hundred miles. I appreciate your concern.
Then you will know the truth, and the truth will set you free.
- Jesus -
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The long plugs won't hit anything because that head is cavernous in the plug area, but they will sieze in the head if you don't get them out soon. Anytime the threads protrude out past the edge of the head metal carbon builds up and siezes things.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | AC Delco R45S gapped at .040" will work fine in almost any 235. Even better if you've got HEI or petronix ignition.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by 4ontheFloor: The long plugs won't hit anything because that head is cavernous in the plug area, but they will sieze in the head if you don't get them out soon. Anytime the threads protrude out past the edge of the head metal carbon builds up and siezes things. Thanks for the warning! Got 'em out tonight!
- Jesus -
| | | | | Joined: Nov 2000 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2000 Posts: 21 | Count the valve cover bolts. 4 Bolts, 2 on each side of cover, generally equals 235.
1948 Chevy 5 window "6" powered
| | | | | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by Larry Day: Count the valve cover bolts. 4 Bolts, 2 on each side of cover, generally equals 235. Thanks Larry, I just checked.... I guess that's what we have. It's got four. I can see a gasket change coming up soon right there.
- Jesus -
| | | | | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by sixpack: The 235 survived through 1962. The Chevy parts guy should know better. If it's a single long pushrod cover, then it's not one of the later motors - they all used two smaller covers. You've probably ot a 235, but check the casting number on the block to be sure. And if the head casting number ends in "848" or "850" then it's either a 235 or 261. Thanks sixpack, We have the 848.
- Jesus -
| | | | | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by Frank54:
Good luck!
Frank McMullen Hi Frank, I looked at the casting #s but can't quite figure them out. Our block was/still partially is blue. Does that mean one particular engine?
- Jesus -
