4 members (originalchuck, TooMany2count, Chip O, Hotrod Lincoln), 78 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#550933 06/29/2009 6:56 PM
Anyone have tricks for installing the rubber bump stops in the lower front a-arm of 67-72 trucks? Ive been tring to get them in but to no avail. I've tried lube with a rubber malle, brute force but nada!
Mac
what kind of lube did you use and werethey on the truck or off ? if they were old ones they can be tough .
Do what I did with mine put them in the freezer overnight shrinks them a few thousandths and they should then pound in. You have to work fast though.
I'll try freezing them. I used white lithium on them to no avail. The tolerances are so tight i guess need to break out the dead blow mallet.
Mac
use some silicone grease on them,start one end at a time .if you can hold pressure on them slot's cleaned out that they go through ,and pry them in with a small blade screw driver.
