3 members (DadsFirstPickup, baldeagle, 1 invisible), 140 guests, and 2 robots.
Topics128,087
Posts1,056,114
Members48,435
LT
Offline
About 3 years ago, I bought a rebuilt 283 V8 long block from an engine rebuilder, but I never installed it (long story won't go into it).
So for 3 years, this engine has been bolted to an engine stand in my garage wrapped in plastic. Now, I want to put into my '59 31 Apache.
My question: should I do anything special with the engine before putting it in the truck? I'm planning to put a little oil on the cylinder walls, squirt oil around on the cam, timing chain, and where ever else I can, and run the oil pump with a priming tool and a drill, but should I be doing anything else?
LT
might crank it a bit w/ no spark to see what it sounds like and get the oil spread around, but if it's been pretty dry stored it should be ok
if ya really wanna be careful you'd open it up and see if it still looks like the shop left it - no film of rust on anything
You can also remove the plugs and hand bar it over and see if you feel an rough spots after a couple of revolutions.
spray a shot of wd40 into the cylinders b4 cranking
Jim & Caroline
I was under the impression that wd40 contains solvents, that will wash away any oil in the cylinder.I would squirt oil in the cylinders. What are your thoughts on this.
1951 3100 Chevrolet
I use BG Inforce for things like this. It lubricates and dissolves rust at the same time. I've started things that have sat for 20+ years and they turn out good, 3 years shouldn't have caused any damage, but you never know I guess,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
LT
Offline
Thanks for the help. I checked with the engine rebuilder, and they also suggested the fogging oil. They also recommended running the oil pump using an oil pump priming tool, but I was going to do that anyway.
BG Inforce sounds like handy stuff to have around too.
LT
My thought---the motor is designed to run with oil in it---so squirt some oil in the cylinders ( I have no idea what fogging oil is, and wonder if it does any better than regular oil..if it did we would our trucks on fogging oil in lieu of motor oil...). Crank it by hand like everyone else said--slowly. Spark plugs should be out. take the valve covers off and watch the rockers and such to find any stuck valves. OIL the rocker arms adn all that good junk. And like the other guy said, it is only 3 years....if it is inside---don't worry about it that much anyway. I have a lawn mower that sat outside for 5 and it came back to life after a new tank of gasoline. Good luck
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
