3 members (keithfielder, Stewart2, Rich'sToys), 122 guests, and 2 robots.
Topics128,103
Posts1,056,534
Members48,448
#550491 06/28/2009 7:42 AM
What's this oil line for?
oil line pic
It's on a '61 235. It runs to the oil pressure tee. Do I need it? I've got the factory assembly manual and don't see any drawing with it.
Also, where would an oil filter plug in. Would it plug in here? oil filter location?
61cheevy #550503 06/28/2009 11:48 AM
You mystery oil proably runs around the back of the engine to about the middle of the head to help carry oil to the rocker arms. Yes the oil filter will plug in there if ti is a 235.
ttodd #550688 06/29/2009 12:41 AM
The lystery line is just what ttodd says, to run oil to the rockers. It is not original equipment, probably added by a po because the oil fed got pugged up due to lack of maintainance.
The oil filter does go to the 2 ports circled. Note that the mystery line is hooked to the back one. That port is the pressure feed for the filter. The other port is the return, and dumps back into the pan.
If you're going to overhaul the engine, I would suggest getting rid of the mystery line, as it is unecessary, then add a filter to prevent the oil feed from getting plugged in the future.
Bill Burmeister
Thanks guys!.
I suspected that's what the mystery line was for. I was gonna run the engine with the valve cover off to see how the rockers were getting oiled, from the tube or somewhere else. Normally, how would oil get to the rockers?
I was hoping to avoid overhauling the engine. Any suggestions on where the "clog" might be or how I could track it down?
On your engine, there is a drilled passage in the block for it. Here is a pic from a shop manual (it's a '59 manual, but is the same) that shows where the passage is.
Bill Burmeister
Longbox, thanks for the info. I have the factory shop manual and found the same illustration. Dunno why I didn't look there first.
I plugged the oil line, took off the valve cover, started the engine and no oil was getting to the rockers. Is there any way of getting to the blocked oil passage without removing the engine? It looks like I can get to the vertical passage by removing the head. What about the horizontal passage?
