7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55048 01/16/2006 2:38 AM | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | I have gone from one cylinder firing to no cylinder firing. I have NEW plugs (Gap - don't remember: What is the GAP?) NEW Distributer Cap, New Wires, New points (was told 18, now I was told to try 30 -- What is the GAP? New Rotor Cap, New Coil (12 Volt) New resister, New voltage regulator, Rebulit Generator, Rebuilt Starter and last but not least, a New battery.
NO SPARK!! Help please!!
One other thing: The wire that comes from the ALT gauge..(green in color) Does it go on the top (1st screw on the voltage regulator?...I think I put it in the wrong place. I put on on the top left screw that bolts the voltage regulator to the firewall. :confused:
Any help would be greatly appreciated!!
Thanks | | |
#55049 01/16/2006 3:18 AM | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | Thanks Jeff..
Any thoughts on the correct wiring on the voltage regulator?
Also if I still do all of that and still no spark, any thoughts on what I should check next?
Jeff S. | | |
#55050 01/16/2006 3:45 AM | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Be sure and check that you have voltage going to that new coil.Also check the gap on the points with the lobe pusing them to thier widest opening they should be gaped to .20. Check all that new stuff you bought because I have found bad parts right out of the box from the parts store.Good luck!!! Hobert
"The Lord is my shepherd"
#55051 01/16/2006 3:47 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I would look for a wiring diagram here, in my shop manual or at the local library. You haven't indicated what model and year. If it was firing on one cylinder only, the firing order must be wrong.
What's an ALT gauge? | | |
#55052 01/16/2006 5:07 AM | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | Sorry guys...55 Chevy PU with a 235 6 cyl. All but one was firing. I have 100 compression on 2 cyl, 95 on two cylinders, 90 on one cylinder and 85 on one cylinder. It was running good one day and just started missing, then one day it acted like it ran out of gas, it started back up and ran for about 10 minutes, and then I found that the coil was so hot, I could hardly touch it. that is when I started replacing parts, and now it just spins and trys to fire but it won't.
thanks for any input. | | |
#55053 01/16/2006 5:23 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The resistor or the starter resistor bypass may be hooked up wrong if the coil overheats. Did you retime it after the changes? | | |
#55054 01/16/2006 8:18 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Sometimes the "pass through" insulator that hooks up to the points from the coil breaks (it's plastic) and starts to short out to ground. This causes the coil to overheat and keeps any spark from getting through. You might want to check it.
#55055 01/16/2006 10:04 AM | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | Where is the pass through insulator? Is that the same resistor that is inside the distributor?
And I said ALT gauage, but meant AMP// | | |
#55056 01/16/2006 1:44 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Just a thought....Some coils have the resistor built in to it and some do not. If you installed a coil with a resistor and also installed an external resistor that could be your problem.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#55057 01/16/2006 6:40 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Sport, I had a miss in my 235. I pulled the plugs and gapped them all to .035. One of them had virtually no gap at all-I assume that was the problem because she's a'purrin now. | | |
#55058 01/16/2006 6:51 PM | Joined: Jan 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 46 | Sport55 - That is a capacitor inside the distributor. | | |
