Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (SWEET, Wickedbass, Hanks custodian, HandyAndy, Ponchogl), 40 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#550391 06/28/2009 12:23 AM
What thermostat should a 1955 235 have. My temp will almost peg and then drop back on the dash gauge. Normal running will put the gauge about 3/4 Could the gauge be reading high.
robert giles #550398 06/28/2009 12:56 AM
180 degrees is typical. Mine runs at the mid-point of the gage.
Make sure it is facing the correct way.
You can check it in a pan of water, with a cooking thermometer for verification. Put it on the stove and measure the temp when it opens.
You might also consider your sending unit and/or gage ground. It is possible the thermostat is working properly, but your readout isn't accurate. I'd do a cal-check to isolate the issue.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=513363
