6 members (Otto Skorzeny, Lightholder's Dad, Hotrod Lincoln, Rusty Heaps, rfs56trk, GRNHydra), 130 guests, and 4 robots.
Topics128,164
Posts1,056,968
Members48,458
#550199 06/27/2009 4:10 AM
What's this oil line for? It leads to the tee where the oil pressure sensor is. Is it a bypass line because there's no oil filter? Can I remove it? Also, how can I install an oil filter?
unknown oil line
I forgot to mention that this is a 235 on a '61 apache
Mine does not have that line. Someone might have put that on to get more oil to the rockers.If you remove the line just make sure you are getting enough oil to the top of the motor. Take the valve cover off and start it up and make sure oil is coming out of all the rockers
I believe that is an add-on line to feed the rockers usually installed when original oil line is clogged/broken/inop. I think.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
