2 members (gswbbc, Gray_Ghost), 50 guests, and 2 robots.
Topics128,035
Posts1,055,446
Members48,422
#55012 01/15/2006 2:57 AM
Just wondering.....how much of the driveshaft spline should be inserted in the transmission. The tranny is a turbo 400? The front insert is 4" with 3 1/2 inches of spline.
#55013 01/15/2006 7:59 AM
3B Offline
Hy blkhrn, As a bare minimum, with the truck sitting on its wheels you should be able to disconnect the "U" bolts at the diff.and be able to take the U joint out of the yoke and swing it clear, a little more clearance than that would be better. There are a lot of custom driveshaft shops out there if you give one a call or find one on line they should be able to tell you how to measure between your trans and rear end and how long the tube and yoke assembly would be with a given slip yoke. Hope this helps.
#55014 01/16/2006 11:43 PM
Its fine
dan-pa
#55015 01/17/2006 12:55 AM
you'll want about 1'' play-out. So as your univ joynt's collar is about 1'' away from the tranny. this leaves about 1'' movement when the truck bounces in it's normal operation and the slip joynt can travel.
Jim & Caroline
#55016 01/17/2006 5:44 AM
Thanks a bunch. I think I've got it lined out now.
