3 members (tclederman, TUTS 59, 1 invisible),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, Where can I find the correct 235 engine oil pan drain plug gasket? What's the correct type of gasket am I suppose to have on the 235? The one that was on there was a really worn our plastic washer that I replaced with a coper one. Since I replaced the gasket, she's been leaving oil spots where ever I park my truck. TIA, David
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | You should be able to get correct ones from GM parts dept. If you do not want to spend the little extra for the GM original part, you can get some plastic ones that are close and they should seal pretty well.
#5499 09/19/2003 11:35 AM | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | I went to ACE Hardware and they had in the bulk hardware section, fiber drain plug gaskets and drain plugs. My ole GMC dosen't leak at the drain plug now! (there are still about 20 other places that it does  ) | | |
