3 members (tclederman, DoubleB, Nick in Manitou), 74 guests, and 2 robots.
Topics128,091
Posts1,056,036
Members48,433
#5497 09/19/2003 7:25 AM
Hi Everyone,
Where can I find the correct 235 engine oil pan drain plug gasket? What's the correct type of gasket am I suppose to have on the 235?
The one that was on there was a really worn our plastic washer that I replaced with a coper one. Since I replaced the gasket, she's been leaving oil spots where ever I park my truck.
TIA,
David
My truck don't leak oil, it just marks its teritory.
#5498 09/19/2003 7:28 AM
You should be able to get correct ones from GM parts dept. If you do not want to spend the little extra for the GM original part, you can get some plastic ones that are close and they should seal pretty well.
#5499 09/19/2003 11:35 AM
I went to ACE Hardware and they had in the bulk hardware section, fiber drain plug gaskets and drain plugs. My ole GMC dosen't leak at the drain plug now! (there are still about 20 other places that it does eek )
1936 GMC T-14 1/2-Ton Pickup
