2 members (Woodcmiami, baldeagle), 93 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#549604 06/25/2009 4:18 AM
I am rebuilding my front axle for my 50 3100, and there is a slight lip where the bearing goes. How much wear is too much?
TexanC3 #549615 06/25/2009 4:46 AM
Most spindles I've seen that are this old do have a bit of a lip, usually where the inner bearing race rides. I think its just 'pounded out' from too many miles & bumps in the road. As long as there's no sign of the race spinning out, like bluing color or galling metal transfer, I run them. Just use good preventive maint. practice like regular inspections & re-greasing.
Doug
desertdog #549657 06/25/2009 10:27 AM
My spindles have the lip also. I converted to tapered roller bearings and the race on the spindle is a little wider. So there is a larger bearing surface.
'59 Apache
'67 Mustang
