10 members (JW51, 68ironhead, baldeagle, Guitplayer, 2-Ton, walter74, Eisenholtz, Peggy M, joe apple, WICruiser),
82
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Maybe someone can help me. Just got the inside of my '58 painted and when I got it back the dome lamp not working. Found that the shop re-plugged some wired on the headlight switch wrong so I fixed it. Now, when no bulb I have one wire power and the other ground. Once I stick the bulb in I have power to to both wires. What gives? Any help would be appreciated.
Thanks, Steve in Idaho | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 |  both wires should go to the light switch, that light is always 'hot', the switch puts the ground to it when turned to the 'click' .... I think the white one is + and the orange is ground, but don't hold it to me  Bill | | |
