| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hello, I assume that there are different carburetors which will work on my stock GMC228 manifold. Does anyone know what works? Are the carbs for a 248 270 302 the same? Thanks, Chris | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Zenith carbs, which is what came on GMCs, were made for a specific engine. A Zenith from a 248 or 270 might "work" on a 228 but you can't expect the kind of performance as from a 228 Zenith. Many people have thrown Rochesters on GMC engines. Again it will "work" but not like the original carb. | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | I've put a carb from a 302 on a 228 with an adjustable main jet, its works but not well as others have said. "More carb don't add fuel they add air. Engine vac adds fuel, too much carb- not enough fuel." You try then to add more fuel with the main jet -. A smaller carb is usually better in most situations.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
