3 members (Bill Hanlon, DES57, Tom McGrath), 118 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#547923 06/19/2009 2:21 AM
Hello,
I assume that there are different carburetors which will work on my stock GMC228 manifold.
Does anyone know what works?
Are the carbs for a 248 270 302 the same?
Chris
Zenith carbs, which is what came on GMCs, were made for a specific engine. A Zenith from a 248 or 270 might "work" on a 228 but you can't expect the kind of performance as from a 228 Zenith. Many people have thrown Rochesters on GMC engines. Again it will "work" but not like the original carb.
I've put a carb from a 302 on a 228 with an adjustable main jet, its works but not well as others have said. "More carb don't add fuel they add air. Engine vac adds fuel, too much carb- not enough fuel." You try then to add more fuel with the main jet -.
A smaller carb is usually better in most situations.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
