| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54937 01/13/2006 6:24 AM | Joined: Jan 2006 Posts: 3 Junior Member | | Junior Member Joined: Jan 2006 Posts: 3 | I have a 1950 3100 that has a 4 speed. I want to change it to a 3 speed column shifter which I have. Does anyone know if the torque tube is OK on length regardless of which tranny you bolt up? I am also converting the 411s to 355s...does anyone have a preference on where to buy the 355s for the best price?
Thanks, Big Caddy | | |
#54938 01/13/2006 4:58 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Hi Big Caddy, welcome to the Stovebolt!
I don't know the answer to your question, but I think there was more than one torque tube length. Maybe my response will move your question up higher and someone who knows will respond.
Where in the Seattle area are you? I know where there is a '52 GMC a ferry ride from Seattle that is now missing its 3-speed that you could probably get the torque tube from pretty friendly.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#54939 01/16/2006 10:44 PM | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | It should be a bolt in replacement, I just did the opposite, 3 speed to a 4 speed, everything bolted right back up. | | |
#54940 01/17/2006 2:18 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Big Caddy,
All Advance-Design 3-speed and 4-speed torque-tube transmissions are the same length.
The only Advance-Design torque-tube transmission that has a different length (longer) is the 1954 1/2 ton Hydra-Matic. As a result, the Hydra-Matic torque-tube is shoter than manual transmission torque-tubes.
Tim | | |
#54941 01/17/2006 4:12 AM | Joined: Jan 2006 Posts: 3 Junior Member | | Junior Member Joined: Jan 2006 Posts: 3 | Thanks, Tim!!!! When you have three trucks to make one, interchangeability is kinda critical! And I would hate to spend the money rebuilding the 4:11s from the 4-speed rearend to 3:55s only to find that the tube doesn't marry up to the 3-speed....
Big Caddy | | |
#54942 01/17/2006 4:15 AM | Joined: Jan 2006 Posts: 3 Junior Member | | Junior Member Joined: Jan 2006 Posts: 3 | Thanks, Hillbilly - that is the beauty of this site...always somebody been there, done that!
Big Caddy | | |
#54943 01/17/2006 5:27 PM | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | One last thought...any difference in the bell housing bolt pattern for the for the two trannys? | | |
#54944 01/17/2006 5:36 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | |
#54945 01/17/2006 9:35 PM | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | Hi Big Caddy,I Have a 53 3100 and want to install a 4 speed and remove my 3 speed.Thank for your posting,now I have some answers to my questions.If you are going to sell yiur 4 speed PLEASE post it on this site.Thank you again | | |
