3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
Junior Member
Junior Member
I have a 1950 3100 that has a 4 speed. I want to change it to a 3 speed column shifter which I have. Does anyone know if the torque tube is OK on length regardless of which tranny you bolt up? I am also converting the 411s to 355s...does anyone have a preference on where to buy the 355s for the best price?
Big Caddy
Hi Big Caddy, welcome to the Stovebolt!
I don't know the answer to your question, but I think there was more than one torque tube length. Maybe my response will move your question up higher and someone who knows will respond.
Where in the Seattle area are you? I know where there is a '52 GMC a ferry ride from Seattle that is now missing its 3-speed that you could probably get the torque tube from pretty friendly.
It should be a bolt in replacement, I just did the opposite, 3 speed to a 4 speed, everything bolted right back up.
Big Caddy,
All Advance-Design 3-speed and 4-speed torque-tube transmissions are the same length.
The only Advance-Design torque-tube transmission that has a different length (longer) is the 1954 1/2 ton Hydra-Matic. As a result, the Hydra-Matic torque-tube is shoter than manual transmission torque-tubes.
Tim
Junior Member
Junior Member
Thanks, Tim!!!! When you have three trucks to make one, interchangeability is kinda critical! And I would hate to spend the money rebuilding the 4:11s from the 4-speed rearend to 3:55s only to find that the tube doesn't marry up to the 3-speed....
Big Caddy
Junior Member
Junior Member
Thanks, Hillbilly - that is the beauty of this site...always somebody been there, done that!
Big Caddy
One last thought...any difference in the bell housing bolt pattern for the for the two trannys?
no difference
Hi Big Caddy,I Have a 53 3100 and want to install a 4 speed and remove my 3 speed.Thank for your posting,now I have some answers to my questions.If you are going to sell yiur 4 speed PLEASE post it on this site.Thank you again
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
