3 members (Southerntruck, KEVINSKI, TPR57C), 176 guests, and 2 robots.
Topics128,114
Posts1,056,287
Members48,439
I'm mocking up my door fits and for the purpose of mocking up I used door rubber that I got about 25 years ago. After paint I'll likely put new ones in. Anyway these rubbers have the plastic pins. They fit great and the doors close very nice however I think due to age the plastic pins have shrunk. I ecpected the pins to "snap" into the holes however they're a loose fit that pop out easily-I won't expect that the plan was for glue to hold them in place..What do you think? underszed plastic pins?
Keith
I've found the plastic pins are rarely a tight fit - the originals had springy metal wire 'pins' that "self adjusted" to hold better, but likely affected the holes over the years [called rust wink ] all the correct metal retainers [bottom and corners], along with glue in a few places as insurance is a necessity, especially around the dogleg
I would just get some 3-M weather strip adheasive an lock it down.
It is good stuff.
just my 2 cents
1952 Chevy Shortbed
Photos in Photobucket
